Hi Guy's,
1st post
But also a fist time experience for me.
I have (up until now) prided myself on having a 100% customer satisfaction rate, based mainly on having fixed everything I have been given. Just general electrical stuff, I have a knack (logic) of making things work again. But if I know it's beyond my knowledge, I stop and admit it, and just hand it back to them. I know my limits, a young player as DJ would say. However, I do want to extended my knowledge and I do that via helpful you tube videos and just messing around.
So guy called me up about a Fluke 2813 System Power supply that had the left hand side of it's LCD blank. He couldn't get anything out of it because he couldn't make out the options. Easy..?
A few plastic clips, cleaned contacts and realigned zebra strips later.. a full display
However, after a more detailed general inspection. I noticed this piece of kit had sustained a substation whack to the left had chassis, but not a mark on the case!?
Even closer inspection revealed no output on any of the 3 power modules, even further each input fuses blown. And they blew again with a new fuse, shorted FET. So I thought I would get at least one channel going, but after parts etc it's show no sign of life
(And without a isolation transformer, nor would I if I continued).The power modules, and PSU module were made by Mitra Power Systems on behalf of Phillips/Fluke. There are no schematics for these modules, and no silkscreen on the PCB either! Except for a hand + - on the cap holes and a random resistor!
I then found out the primary FET heat sink was at -150v even though the FET was isolated from it. I got on channel of it no to blow it's fuse, but this thing is shafted. Whatever took all three PSU's out at once has clearly caused a whole load more damage.
So I find myself in unfamiliar territory. I've never really given up on anything beforeIt's basically a nasty piece of work and I don't wan't to touch it. If it's shorted primary ST BUV45A's, I thought I would replace one and associated caps and 1 reg but there is at least another 12 semi's that could also be screwed and then x 3. Hey it never blew the fuse afterwards... :/
This must be a noob thing, and I probably should have stopped long before I did. My instinct tells me fix it, don't stop until it works. But my brains says, this is someone who's bought a Fluke made by Phillips, but with the main PSU, and all the output PSU's made by someone else (Mitra Power Systems, hence no schematic, with no silkscreen or numbered components, hunting around in the dark with -150v heatsinks... (why would you leave a heatsink on a -150v rail if the FET stuck to it was isolated!!).
I'm sorry this is so long, but for the first time I think I'm justified in handing this thing back to the guy and wishing him luck! I might have to nurse my ego a bit, it hurts as my real first fail to fix. Do you remember going through something similar on a first beyond-economic-repair??
