Hello guys! first time on the forum. I'm beginning to fiddle with electronics and I do a lot of component recycling. The problem is that I can't seem to find a good way to straighten the leads of the components I've used. I borrowed some from university and I'd like to return them in mint condition, I tried using some long nose pliers (exactly like this one) with my transistors but it seems like it's doing more damage than good to the poor thing.
So I'd like to know if you have any good tips & tricks or if you can recommend me a good tool for the job.
Thanks!
The one you show has teeth -- Don't use one with teeth.
Use the smooth surface one. Choose a shape you like, but smooth surface like this:
Do the horizontal, rotate, and do it again. After just a few presses, it will look as straight as new from the shop. The shape doesn't matter so much as long as the surface is smooth. The gripping teeth will not smooth the wire.
Rick
EDIT: I want to emphasize, you don't use this to bend it back to shape - you pressure-press the bend out between the flat surface. Where there is a bend, let the bend sit vertical against one of the surface and press down on the bend to remove it.
