That's NOT a Hall effect sensor.. It is basically a transformer secondary. The wire you pass through the center hole forms the primary. It will only detect AC current, not DC.
If that is what you want, connect a 50 Ohm resistor between the 2 pins and measure the AC voltage across the resistor.
