I had trouble finding many solder tip selections when I bought my Hakko so had to stick with one that it comes with, but did find lot of rip off ones off Amazon, just not official ones. Are the rip offs worth while? I know they're rip offs because there's like 10 in a package when 1 real tip is same price. My solder is 0.8, suppose I can look at ordering a roll of smaller one. Anything in particular I should look for?
It really doesn't matter. I use a blunt chisel tip and it works fine.
How do you get the chip to stay put, is there a glue I can use that won't melt at solder temps? I suppose this would be easier if I had an actual circuit board but since I want to prototype and not actually get a board made I need a way to solder it to a perf board. I have solder paste as well if that might be easier. Never worked with it before and don't have a reflow or toaster oven though. Would heat gun work? I can maybe look at hooking up my camera to HDMI with macro lens for magnification. Though the slight video delay would make it a bit awkward I think.
For small packages, like resistors and caps, put solder paste on the pads, set the part and hold it down with tweezers while you hit the joint with the iron.
For big packages (ICs and such), position the part with tweezers, run a bead of flux along the pins, finalize the position and tack a corner. Then tack an opposite corner. Now you can drag solder the rest of the chip. You can drag solder using conventional solder or you can run a small (VERY small) bead of solder paste over the pins.
I use both conventional solder and solder paste depending on which I think will be easier at the moment.
As a side note, how do you stop the PC pin plastic from melting when soldering PC pin headers? Figured I'd start by making the 8 pin board and half of the pins just sink through plastic from the solder heat.
Get in, get the pad soldered and get out. Don't hang around heating things up.
Here's where I get my solder paste and flux. Buy some small needles (red and yellow) as well:
http://www.howardelectronics.com/You need some good tweezers, both straight and curved
https://www.sparkfun.com/search/results?term=tweezersI'm using an OptiVisor #10. I had to buy the lens separately because the normal lens just didn't do what I wanted when checking for solder bridges. I would love to have a microscope but they're a little too expensive.
Besides, I use a toaster oven more often than not!
For breadboarding awkward packages, see SchmartBoard for adapters:
http://schmartboard.com/
