Author Topic: How does the DVB-T2 Dongle work?  (Read 1158 times)
Online Lord of nothing
  • Country: at
« on: November 12, 2016, 12:11:52 pm »
Source: http://mysku.ru/blog/ebay/20164.html
I have an MN88473.
So how does the Dongle work?
The Signal does first into the: http://www.rafaelmicro.com/product/view/21 and get demodulated?
After to the Panasonic MN88473 and what does do it there?
Than into the http://www.realtek.com.tw/products/productsView.aspx?Langid=1&PNid=22&PFid=35&Level=4&Conn=3&ProdID=257 and get send into usb?
I try to find the limits of the Chips. The "TV" Software allow me to set AM, FM and NFM in the Radio Setting .ini  :-DD.
I know its possible to run the Dongle with SDR Software. So maybe I get run Amateur Radio in the normal Radio Software?!
Made in Japan, destroyed in Sulz im Wienerwald.
Offline stj
Re: How does the DVB-T2 Dongle work?
« Reply #1 on: November 12, 2016, 12:27:14 pm »
the rafael chip is a tuner,
realtek is a fast A-D,
most of those dongles only use 2 chips.
the tuner and a very fast A-D sampler.
all demodulation etc is done in software.
http://sdr.osmocom.org/trac/wiki/rtl-sdr
  • Country: at
« Reply #2 on: November 12, 2016, 12:30:13 pm »
What did the Panasonic do there?
So that mean there is no limits for the Software?
Offline stj
« Reply #3 on: November 12, 2016, 12:50:34 pm »
the rafael chip can tune from about 30MHz to about 1.7GHz,
other than that, it's down to your processing power and the antenna.
  • Country: at
« Reply #4 on: November 12, 2016, 12:53:29 pm »
Some people say there is some kind of hardware decoder inside?!
Maybe you can explain why the DVB-T Dongle cant Decode DVB-T2?  :-//
Offline stj
« Reply #5 on: November 12, 2016, 01:00:27 pm »
maybe it can - with the right sofware.
