I can only repeat what others have said about lead acids, they're very dangerous if not used *and charged* correctly.
For my needs, I've got a 0-30V, 10 amp supply, a TOPS3D 3 output dual tracking and 4-7V variable supply (tortuous description but...) and a Farnell L30BT which is dual 0-30V 1 amp.
I find I use the 10 amp supply most often as I repair transceivers, the TOPS3D is useful for audio work and the L30BT, it's not really used that much now, I could probably sell it and not miss it.
For higher power radio gear I use a couple of 17AH SLA batteries, fused at 50 amps and charged with a caravan battery charger which has an SLA mode.
