Author Topic: How much ac leakage across a transformer is normal?  (Read 1954 times)
Offline CoolJosh3kTopic starter
    • TF2TightRope.com
« on: May 01, 2017, 01:24:59 pm »
So I noticed when I hold onto the metal frame of my lamp, whilst I touch the side of my hairy arm against the metal base of my microphone, there is some electrical continuity.
I confirmed it to be my lamp with a multimeter between it's metal frame and my kitchen sink. It shows AC with around 400 to 600 micro amps.
Before I call my lamp faulty and bin it, how much ac should normally appear like this? Is this nothing to worry about at all?
Thanks for any help.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: How much ac leakage across a transformer is normal?
« Reply #1 on: May 01, 2017, 01:29:50 pm »
For a real transformer that is too much.
For a switchmode supply that is normal.
Generally below 1 mA is allowed. See local regulations.
The following users thanked this post: CoolJosh3k
    • TF2TightRope.com
« Reply #2 on: May 01, 2017, 01:42:45 pm »
Ah, thanks. Nothing to worry about then if I ever get tickled like that.
As a follow up question...
Why is it more strict for a normal (linear?) transformer?
Offline helius
« Reply #3 on: May 01, 2017, 02:13:15 pm »
Switchmode PSUs contain EMI suppression capacitors that couple some of the input AC to the case. When the case is earthed, it travels to earth. When it isn't, you can sometimes feel the current passing through your body. 1 mA is approximately the threshold of sensation—20 mA and above could be dangerous. Some countries place the safety limit at around 400 uA, but the regulations for different types of equipment differ.
    • TF2TightRope.com
« Reply #4 on: May 01, 2017, 03:00:09 pm »
Where would one find local regulations?
What is the proper way to read the current? I figure chassis to sink is not too typical.
Offline Gyro
« Reply #5 on: May 01, 2017, 03:51:44 pm »
That's where setting your country flag in your profile comes in really handy.  ;)
If you're in a country that requires proper grounding of all plumbed fitting then chassis to sink, radiator etc is really quite appropriate.
P.S. If doing this sort of test, then it's a good idea to be cautious and insert some sort of safety series resistor in series with your meter, untill you've established that it is just leakage current and not a situation where the chassis really is Live. It might save you a meter fuse, nasty flash, or much worse (depending on the quality of the meter).
« Last Edit: May 01, 2017, 04:04:24 pm by Gyro »
Best Regards, Chris
Offline Zero999
  • 0999
« Reply #6 on: May 01, 2017, 06:22:32 pm »
It isn't more strict for a real transformer. It's just switched mode power supplies tend to be more leaky because of the Y capacitor.
    • TF2TightRope.com
« Reply #7 on: May 02, 2017, 07:47:42 pm »
I have updated my profile.
