Author Topic: How much noise on power rail is normal?  (Read 13961 times)
Offline chickenTopic starter
  • Rusty Coder
« on: July 11, 2014, 01:29:48 am »
I work on a project with an MCU and a radio receiver IC. It works well, but more range/sensitivity is always better B-)
The receiver IC claims sensitivity down to less than -100 dBm, but in my design packet integrity starts to drop off around -60 dBm. The radio reports an RSSI close to the absolute minimum (-120 dBm) when not connected to an antenna, jumping to -110 to -90 dBm depending on antenna. But I doubt this is reflective of the actual noise floor. The radio being a single IC makes it hard to diagnose that part in more detail.
Checking out the 3.3 V power rail I see about 10 mVpp of noise, with a prominent (IIRC mostly upward) bump at around 10 kHz. This probably correlates with the 9600 bps data clock waking up the MCU and toggling an indicator LED.
All capacitors recommended by the datasheets and app notes are in place. And with less than 30 mA drawn, the 150 mA LDO has plenty of headroom.
Is it worthwhile trying to squeeze out those 10 mV? I.e. will it make a difference?
If so, how? More capacitance? Separate power trace to the radio? Or even give the radio its own LDO? Or separated grounds that are joined near the LDO?
Offline m12lrpv
Re: How much noise on power rail is normal?
« Reply #1 on: July 11, 2014, 02:39:03 am »
Facing the similar issues myself with a project I'm working on and because of that I'm also very keen to get some tips on smoothing out the power rail.
Decoupling as per data sheets just never seems to work. Increasing the capacitance by a factor of 10 or more helps but never really resolves the issue.
Offline kizzap
« Reply #2 on: July 11, 2014, 04:47:59 am »
some sort of LPF would be useful. There are numerous ways to implement it too.
a common method is to have either a RC or LC LPF at the input to the device, bringing the -3dB point to somewhere well before the frequency you are concerned about. for example, if you make a LPF with the -3dB point at roughly 1kHz, iirc you should have a -20dB reduction in the peak of the 10kHz signal, or a ÷10 in peak value.
other methods have different pros/cons, and YMMV.
-kizzap
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Offline VK5RC
« Reply #3 on: July 11, 2014, 04:56:43 am »
I am not an expert in the area but digital and rf don't mix well,  the harmonics from a digital signal go a long way,  I would tend to have two power supplies,  regards Rob
PS also watch the 'ground'  as well.
« Last Edit: July 11, 2014, 04:58:57 am by VK5RC »
Offline Richard Crowley
  • KJ7YLK
« Reply #4 on: July 11, 2014, 06:03:35 am »
The receiver IC claims sensitivity down to less than -100 dBm, but in my design packet integrity starts to drop off around -60 dBm....
Yeah, maybe.  It seems like it would be simple enough to do an experiment where you power the test circuit from a battery (with a few capacitors of various types and values  for good measure).
What leads you to believe the noise is getting in through the power supply after that experiment? I would far more suspect it was simply getting in through the antenna. I would at least perform a test enclosing the receiver within a metalic shield with a proper coaxial antenna connection.
Offline AndyC_772
« Reply #5 on: July 11, 2014, 06:32:59 am »
It's impossible to advise on this problem without seeing the physical layout of your circuit. Can you post a photo showing exactly how it's constructed?
Online David Hess
  • DavidH
« Reply #6 on: July 11, 2014, 09:26:58 am »
RLC decoupling used to be common with a single layer inductor wound directly around a low value resistor which is needed to lower the Q.  This can be applied separately to different circuit blocks to prevent both incoming and outgoing noise.
Wideband decoupling requires low parasitic capacitance in the inductor and they make special ferrite beads for this that are incredibly effective.  At high frequencies just the circuit board trace acts as the inductor.
Ground and power loops need to be avoided.  If a ground plane is used, slots can be used to route digital return currents away from sensitive nodes.
A 10 millivolt change might just reflect the load regulation of the LDO when driving the LED.  Be careful about routing the power and ground currents for the LED through sensitive nodes.
Offline lgbeno
« Reply #7 on: July 11, 2014, 01:04:37 pm »
Before you try to reduce the noise, maybe you want to wire in a external "cleaner" source directly from batteries or some linear ac supply
Online David Hess
  • DavidH
« Reply #8 on: July 11, 2014, 04:08:07 pm »
He says it is already using a LDO regulator so I am not sure how much cleaner it can be.  I would assume most of the noise is coming from the microcontroller and associated digital circuitry.
Offline lgbeno
« Reply #9 on: July 11, 2014, 04:16:30 pm »
Yeah seems like a very nebulous endeavor.
Also noise means a lot of things.  "Thermal noise", "noise" from digital circuits, etc etc.  it's difficulty to optimize and measure.  Just because there is 10mV of fuzz on a scope, how much is measurement uncertainty or attributed by the scope it's self.
  • Rusty Coder
« Reply #10 on: July 11, 2014, 04:55:42 pm »
Thank you all for chiming in, great suggestions!
First of all I apologize for not using the right terms. I'm clearly the n00b here. To clarify terms, I talk about 10mV ripple. The ripple looks roughly the same across the whole rail (close to LDO, close to MCU, close to radio) with a prominent bump roughly every 10ms. The rest is not perfect, but clearly less than 5mV.
Great input. I will definitely try to use a battery to test if a clean supply actually makes a difference.
LPF with LC or ferrite bead is something that I will try as well. But I wonder if ferrite beads are any good to filter this kind of ripple. The datasheets of the SMD beads I looked at all talk about 1MHz+.
I already covered the radio part of the PCB with an RF shield. In field tests it didn't seem to make much of a difference, but hard to tell without being able to measure the noise within the receiver circuit.
See attachment. I highlighted the 3.3V power rail in red.
I think this to be a red herring myself. The IC is tuned to the frequency of interest (~162MHz) so RSSI probably just measures the level of white noise. Transmission errors (CRC) start to get very frequent at RSSI levels 30dBm higher so I wonder if the power supply ripple disrupts the radio's decoding from GMSK to bitstream.
Thank you all again for chiming in. Really appreciated!
Online David Hess
  • DavidH
« Reply #11 on: July 11, 2014, 05:16:36 pm »
They will not do anything for the low frequency ripple but often the problem is the high speed edges accompanying it.
Online David Hess
  • DavidH
« Reply #12 on: July 11, 2014, 05:24:54 pm »
The difficulty of probing and measurement is definitely not to be overlooked.  I have spent my own share of time tracking down phantom noise problems.
The two techniques I like to use are soldering a coaxial pigtail into the circuit to make a coaxial connection to the probe and of course differential probing.  The coaxial pigtail is very handy when leaking magnetic flux in a switching circuit would otherwise contaminate the signal via the relatively large loop area of a traditional probe and ground lead.  Low power supply impedances make the added capacitance of the pigtail insignificant.
One thing I like to do is separately trigger the oscilloscope on different frequency sources in the circuit to see if the measured noise correlates with any of them.  This type of measurement is why good oscilloscopes include an external trigger input.
Offline AndyC_772
« Reply #13 on: July 11, 2014, 06:18:58 pm »
OK, good PCB image, thanks. Can you also please show exactly how and where your probe is connected?
I suspect, as others have already mentioned, that what you're seeing could be more down to the non-ideal nature of a real scope probe than a genuine noise problem in your circuit. Tektronix have a really good app note on probing technique which is well worth a read:
http://circuitslab.case.edu/manuals/Probe_Fundamentals-_Tektronix.pdf
  • Rusty Coder
« Reply #14 on: July 11, 2014, 07:10:54 pm »
I probed the rail side of C10, C31 and VCC on the pin header. The signal looks roughly the same at all points. I use the little spring provided with the probes for grounding to a point as close as possible to the probing location.
The ripple disappears when I exit receive mode (i.e. disable the 10kHz interrupt / LED toggling). So while the probe might add some ringing, I'm pretty confident the ripple is real.  I'm a lot less confident whether the ripple actually is an issue :)
Offline AndyC_772
« Reply #15 on: July 11, 2014, 09:29:48 pm »
Sounds like you know what you're doing. One possibility is that the source of the noise is the LED current being switched on and off, especially since your power rail appears to be routed rather than being on a plane of its own, so it'll be quite inductive. Try removing the LED and see if that helps.
Offline madires
  • A qualified hobbyist ;)
« Reply #16 on: July 11, 2014, 10:10:03 pm »
Which RF band, which modulation and which protocol? The noise on the power rail could be a red herring.
  • Rusty Coder
« Reply #17 on: July 11, 2014, 11:30:48 pm »
162 MHz (marine VHF), 9600bps GMSK, HDLC - basically an AIS receiver.
Here's the project in detail:
http://forum.43oh.com/topic/4833-potm-daisy-a-simple-ais-receiver/
And its current incarnation looks like this:
One thing I probably should mention is, that the IC does not support GMSK natively. See this thread:
https://www.eevblog.com/forum/beginners/need-some-help-with-si4362-(gfsk-vs-gmsk)/
No idea if that has an impact on sensitivity or is just another red herring. Unlike using a scope probe, I definitely don't know what I'm doing when it comes to RF :)
PS: it's fully functional, I'm in the stage of trying to optimize performance
« Last Edit: July 11, 2014, 11:36:04 pm by chicken »
Online David Hess
  • DavidH
« Reply #18 on: July 12, 2014, 12:17:08 am »
I am very dubious of the out of channel overload capability of these direct conversion receivers.  Insufficient out of channel selectivity could explain the behavior you are seeing.  The RSSI signal strength could just reflect the AGC being pumped by strong local transmitters nowhere near your receive frequency which further lowers the sensitivity.
What I would try is building a helical resonator for 162 MHz or finding an appropriate bandpass filter and inserting that between the antenna and receiver.
  • Rusty Coder
« Reply #19 on: July 12, 2014, 12:58:47 am »
I have a cheap handheld radio (UV-5R+) that can send on the channels in question (A 161.975 and B 162.025 MHz), though no AIS messages. When using it as signal source the received RSSI on the same channel is -10dBm, on the other channel the receiver reports -80 dBm.
The radio specifies "spurious emissions" as < -60 dB. The Si4362 specifies 60 dB adjacent channel selectivity with 12.5 kHz channel spacing. So that seems to be within spec. No idea if that's a good or weak spec :)
Will look into this.
Thanks everyone for the great input.
Offline HackedFridgeMagnet
« Reply #20 on: July 12, 2014, 01:25:53 am »
10mseconds -> 100Hz.
Maybe linear psu, 50hz mains supply, full bridge rectifier?
Sounds pretty normal.
  • Rusty Coder
« Reply #21 on: July 12, 2014, 01:51:47 am »
My bad, I failed at f -> t conversion. It's definitely 10kHz / 0.1ms
Offline madires
« Reply #22 on: July 12, 2014, 12:50:56 pm »
I'm no RF expert either, but I'll try my best :) The RF signal strength doesn't tell you anything of the quality of the signal. It may be distorted or mixed with several reflected waves of the same signal and so on. Some modulations are quite sensitive to such issues and other are able to cope with that within some limits. AFAIK GMSK is one of the latter. The demodulation needs some margin to be able to detect the frequency changes of the signal properly. If you're doing the demodulation in software (not the SDR way), I'd think that the required margin is larger than for other methods. Maybe some RF expert could chime in and give us more hints or even some numbers.
Offline Christe4nM
« Reply #23 on: July 12, 2014, 03:36:31 pm »
Hi. I read through the topic and I'd like to chime in regarding noise. I don't know anything useful about RF so I cannot answer if mitigating noise is going to help the RF signal strength issue. Yet I do see some possible noise-related issues in your layout.
So how much noise on power rail is normal?
First of all regarding the amount of ripple and noise that is 'normal': this is purely determined by what the circuit excepts. Example given: if you have 2Vpp ripple on rectified AC before a regulator that might be perfectly 'normal'. Yet your 3.3V MCU has operating limits for the supply voltage so it needs to be within that limits.
That said, it does not mean that you can just leave all kinds of ripple and noise on the supply rail as long as it is say 3.3V +-10%. But noise in itself is not the problem... It becomes a problem when there is an electronic circuit that needs needs to operate and function correctly. Further along the line there are EMC regulations too, to make sure the circuit does indeed behave as intended even with all kinds of noise present. That, and to make sure that your circuit doesn't disturb other circuits as well.
OK, on to some practical stuff. I look at your layout and a few things got my attention. I'll try to keep it not too long as there is plenty of great material already present on the forum.
1) Decoupling cap layout.
First thing to note is that decoupling caps should always be placed between the powersource and the MCU/IC. Also the smallest cap (in value) must be placed closest to the MCU/IC. Why? Well their function is to provide the (initial) current for fast changing loads, giving the regulator time to react to the changing current demand. These fast changing loads are for example your digital communication circuit where every time it switches from 1 to 0 and vice versa the current demanded by the IC from the supply changes. To prevent these changes echoing through the supply the bypass caps are placed to provide that current. Another way to look at it is that they provide a bypass path for high frequency on the supply rail. So those frequencies cannot go beyond the capacitor and enter the supply rail. Note that it works both ways. The IC will no longer 'push' high frequency ripple on the rail, but high frequency ripply won't get to the IC either. This is only part of the picture which I will explain below.
So what you want to do is always place the smallest cap right next to the IC's supply pins, if possible directly over the VDD and GND pins. In other words:  Regulator -> Largest value cap -> smaller value cap -> smallest value  cap -> IC pins.  Make sure the traces always go through the pad of the capacitor. Think of a tollbooth at a highway. You don't want to place that using a off/on ramp, since the majority of traffic will drive right past it. You want to place those tollbooths right on the highway to make sure everyone must go through.
* In your layout you should swap the places of C11+C12 and C10 (if I'm correct to assume that the psysical larger cap is indeed a larger value cap.)
* You should also move C21 so that is sits between the regulator and C22+C23.
* I can't see what C20 is doing, but if it's a bulk or bypass cap, consider moving/rerouting
* Same for C31
2) Why those datasheet values (sometimes) don't work - pt1
What I said above is actually oversimplification of what is going on. In reality it all about the smallest impedance as seen by the frequencies superimposed on the power rails. What you want is that if you have a ripple or noise of some frequency on your rail, that it can be 'shorted' to ground somewhere. Where? well right at the source is the best. How? By providing a path over very low impedance specifically for the frequencies of interest.
This is where the bypass caps come in. Each capacitor has a specific impedance curve over frequency that looks like a V. A capacitor's impedance is very high for low frequencies. That is exactly what we want, since the DC must 'reach' the IC. When we go up in frequency the impedance of the capacitor drops until it reaches the minimum. This is the frequency(range) where it shines as bypass capacitor. Go higher and the impedance actually increases again due to (parasitic) inductance. So in reality that 'rule-of-tumb 100nF' bypass cap, might not do anything at all for the frequency content present in your circuit.
What I tend to do is always leave room for at least one extra bypass cap. That way I can measure the actual ripple and decide to place additional caps later.
3) Why those datasheet values (sometimes) don't work - pt2
Did you know that your 100nF capacitor is not 100nF anymore when put into your circuit? Why? Well the capacity for some capacitors (at least ceramic caps) is voltage dependent. The higher the DC voltage, the lesser the actual capacitance. This results in the impedance curve shifting to lower higher frequencies. Guess what that means for your ripple and noise? Yep, it might not be bypassed anymore as the impedance of the cap for the frequency of interest might actually be in the inductive 'early' capacitive region and much higher than expected.
4) Routing power rail traces - pt1 the journey out
So you want your supply rails as clean as possible. Well in addition to decoupling of noise, you need to route them carefully and away from noise sources. Traces underneath a crystal, oscillator or clock is a big NO. But what about that trace under your MCU? Well, better not do that either. Your MCU is quite a noisy beast, even at low (aka kHz) frequencies. That is due to the harmonic content in digital electronics. It's not just the fundamental frequency, but usually getting up to the 100's of MHz in harmonics. This all depends on the rise- and fall times of the edges of your signals. Even a 1Hz squarewave can generate GHz content of noise if its rise- or fall times are fast enough (sub nanosecond).
In addition you want to keep your 'sensitive' traces away from noise sources. There are rules of thumb for that like 'keep a distance of 5 times the noisy traces' width'. Look that up with your friend Google.
* In your case I'd reroute that power trace away from under the MCU. What you could do is putting a ground pour on the top layer right under the MCU and routing traces on the other side a.k.a. the bottom layer.
5) Routing power rail traces - pt2: where does the return current go?
A good way of thinking when routing your PCB is to think in currents going somewhere. This is because currents always flow in a loop, so it helps you to keep your head in the game by realizing that those currents must go back somehow.
OK, but I've poured a ground, that should do it right? Well, that depends. Try to visualize where the return current will flow though the ground pour/plane. If is has to make a detour to get back to its source, well rather not. If that detour takes it through noisy areas: change your routing.
6) 'Helping' the bypass caps.
It can really help to suppress noise by adding a small resistor (1R or 10R) in the power rail just before the bypass caps. You've now created a low pass filter which enhances filtering. Instead of the resistor a ferrite bead can help too. Don't be fooled by their impedance rating at some frequency: look at their impedance over frequency curve. What you want is something that presents a high impedance or resistance at the frequencies you don't want. Yet at the same time a very low impedance at the desired frequency. For DC that desired frequency is 0 of course.
Phew, this has turned into way more that I intended. Hope this helps.
To the OP:
If it were me I would start with the items I marked with a *. Yes I know, redoing a board isn't that fun: you probably spend quite some time routing it the first time, you are pressed for board space and you have already spend money on the boards and components. Still it might be worth a try.
edit1: typos
edit2: correction in item 3)
« Last Edit: July 12, 2014, 04:14:44 pm by Christe4nM »
Offline tautech
« Reply #24 on: July 12, 2014, 04:02:39 pm »
@ Christe4nM
 :clap:  :clap:
Avid Rabid Hobbyist
