So I recently bought a psp and one issue with it is battery life. 2-3 hours before it is completely dead. I looked around and bought same fake batteries for it off ebay, while they work, they aren't any better. So I got to looking around to see if anyone has ever made what I was looking for to solve this problem, alas nobody really has. So I put it on my shoulders to figure this out and hopefully write a tutorial later down the road if it works out, for anyone looking to do the same in the future. Because the battery life problem will only get worse and harder to find replacements as time goes on.
My goal is to make a battery pack that mounts on the back of the psp to boost the battery significantly. This is what I've come up with:
First is to use two 18650s (
https://www.amazon.com/gp/product/B00WFXWUOE/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1) wired in parallel using this (
https://www.amazon.com/gp/product/B01EJ9H79Y/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1) battery holder. This will add 6800mah to my 2200mah battery giving a big boost.
From the battery holder I will use this step up converter (
http://www.prodctodc.com/ultra-mini-dc-256v-to-412v-step-up-converter-3v-to-5v-1a-phone-charging-module-mobile-power-supply-p-204.html#.WU1KIGjyuHs) to boost the 3.6v to 5v to allow the psp to charge. I will sacrifice a cheap charging cables end to go from the step up converter to the psp's charging port.
After ensuring everything fits and works correctly I will make a custom box from a larger hobby box to house all the components. After ordering everything and thinking about it, the only thing that is really missing is the ability to charge the batteries without taking them out of the pack. Which would be a great feature to add to this. So after some more digging I found this (
http://www.ebay.com/itm/USB-5V-1A-1S-3-7V-Li-ion-Lithium-18650-Battery-Charging-Module-Charger-Board/172451426542?ssPageName=STRK%3AMEBIDX%3AIT&var=471295660016&_trksid=p2055119.m1438.l2649) Which I believe is what I need to charge the 18650s. What I am unsure of is how to connect this to the rest of the theorized battery bank.
My first thought is to just solder the battery case wires and the wires going to the stepup converter input to the output of the charging module. But I feel like if I did that and was charging while it was plugged into the psp it would send power through the stepup converter and cause some issue?
I'm not an expert at making custom things like this, I've done a good amount of repairs and feel confident in my ability to make this work. Just figuring out exactly what goes where is what throws me off, since I have little experience doing any kind of custom electronics. I'm trying to keep this as compact as possible. I have roughly 2 3/4"x 2 1/4" to make this work in. As far as thickness for the box that isn't limited, but obviously the thinner the better. So I don't have a lot of room to put stuff.
If anyone sees an issue with my design, can answer my question about where to put the charging module or has any other tips it would be greatly appreciated.
