Provided the maximum voltage across the thermistor is less than about 600V, then yes. This is simply 75uV times 24 bit ADC resolution, + or -.
Is this useful? No.
What is more useful is what accuracy you can achieve, not to mention precision and repeatability. Resolution on its own is meaningless, just replacing a 16 bit ADC with a 24 bit ADC increases the resolution, but not necessarily accuracy, precision or repeatability. This is where you have to take into consideration the individual errors of each component.
