Electronics => Beginners => Topic started by: Yaro on January 21, 2015, 10:23:14 am
Hi All,
I want to ask how I can detect noise on a line and how to determinate when it may have effects on digital or analog connection quality. For example, I've a digital and an analog line and a 100Khz noise on this 2 lines. How I see this noise on oscilloscope? Also, I was interested in Hantek 6022be but i've read there is a noise of about 20mV on input signal, should this affect my noise detection?
I have also a question on filters, assume I want to use a low pass filter that suppress high freq. , but if I use this filter before an MCU power supply that work at in Mhz range, there may be problems? Inductor may act like a resistance or something like this?
Thank you.
Hi Yaro,
What do you mean by noise on a line? Are you talking about noise on a mains power line e.g. 110V / 240V AC, a telephone line or something else?
HalfSpace :)
For noise I mean EMI noise and inside circuit noise like generated by a stepper motor. I want avoid to use external shield and want to use an inductor filter, but how this may affect digital parts of the circuit?
Hi Yaro,
Using an oscilloscope to detecting EMI noise can be difficult; a spectrum analyzer is a better choice as it will display the frequency of the EMI so you design a low pass filter with the correct roll off frequency to suppress it. Here is a link to build some simple magnetic field probes that can be used with spectrum analyzer to detect EMI. http://www.compliance-club.com/archive/keitharmstrong/emc_testing1.html. (http://www.compliance-club.com/archive/keitharmstrong/emc_testing1.html.) The probes can be used with an oscilloscope if you wish but should be terminated into 50ohms.
Using an LC type low pass filter on a DC power supply rail is ok but use a PI type. For a driving circuit use a T filter. If the EMI is a radiated magnetic field LC filters may not work and a metal shield might be the best choice.
As to how these filters may affect the digital part of your circuit, we will need to see the design to make a judgment.
HalfSpace :)
Could anyone reply me more information of Hantek6022BE? Is it good for a beginner? I'm considering to buy one.
Read these links here on the forum. Others have already discussed it well.
https://www.eevblog.com/forum/testgear/hantek-6022be-will-it-work-for-me/ (https://www.eevblog.com/forum/testgear/hantek-6022be-will-it-work-for-me/)
https://www.eevblog.com/forum/testgear/hantek-6022be-20mhz-usb-dso/ (https://www.eevblog.com/forum/testgear/hantek-6022be-20mhz-usb-dso/)
https://www.eevblog.com/forum/testgear/hantek-6022be-20mhz-usb-scope-review-ish/ (https://www.eevblog.com/forum/testgear/hantek-6022be-20mhz-usb-scope-review-ish/)
https://www.eevblog.com/forum/beginners/hantek-oscilloscopes/ (https://www.eevblog.com/forum/beginners/hantek-oscilloscopes/)
https://www.eevblog.com/forum/testgear/hantek6022bl-2ch16logic-compatible-with-saleae/ (https://www.eevblog.com/forum/testgear/hantek6022bl-2ch16logic-compatible-with-saleae/)
Thank you very much!
