Hi
Simple answer for most small gizmos:
The output is spec'd as DC. There is no power factor, amps X volts gives you power.
The input is rated simply in terms of current. That matters for fusing so it's a relevant spec. As mentioned above, the power factor on a lightweight transformer is likely pretty terrible. Maybe half of the current goes to power, the rest is just wasted energy. The efficiency of the device is on top of that. If you have a 70% efficiency on top of the power factor it all sums up.
Next up you have the somewhat odd fact that even on resistive load stuff, they can't seem to get the numbers right. If you spend some time checking appliances, they pretty much never pull to much current. They often pull 20 or 30% less current than they should. Why should? If I bought a 500W toaster oven ... it should be 500W. In this case it's both tolerances and marketing.
Bob
