Author Topic: How to identify a zener plus ptp wiring.  (Read 1667 times)
Offline HextejasTopic starter
« on: January 17, 2018, 11:56:58 pm »
When I am doing some breadboarding and am finished, there are usually 1 or 2 zener diodes that I have used.
Question is how the heck do I identify them so I can refile them ? They are so tiny. I have been throwing them away. 😂
Next is that I would like to try my hand at doing some ptp wiring. I am not eager to start making my own pcb yet, so this seems like a fair compromise. Are there any kits that do this ? I th8nk that I need some kind of a wire wrap tool ( I have one ), plus some size of wire ( I have some 22awg ), a blank pcb with holes in it, and I guess some headers ?
Did I miss anything ?
Thanks
Offline Benta
Re: How to identify a zener plus ptp wiring.
« Reply #1 on: January 18, 2018, 12:38:10 am »
OK, I'll bite.
What's "ptp wiring"? Google returns gibberish.
Perhaps a well-phrased question would give more answers?
Offline jaycee
« Reply #2 on: January 18, 2018, 12:57:29 am »
point to point wiring
Offline Benta
« Reply #3 on: January 18, 2018, 01:06:08 am »
Makes very little sense in the context of the original question...
Offline james_s
« Reply #4 on: January 18, 2018, 01:21:24 am »
I use a resistor, power source and a multimeter to identify zeners. Just take a resistor of say 1k-20k, value is really not critical and connect it in series with the zener, then connect that to a DC source that is higher than the highest voltage zener you want to measure. Put the meter across the zener and you will have the value.
The following users thanked this post: Hextejas
Re: How to identify a zener and how to equip for point to point wiring.
« Reply #5 on: January 18, 2018, 04:32:04 am »
Well I hope that is clearer. 2 completely different topics.
I hope that its permitted.
« Last Edit: January 18, 2018, 04:34:22 am by Hextejas »
Offline james_s
« Reply #6 on: January 18, 2018, 06:39:20 pm »
Permitted yes, but not really recommended. You are more likely to get good replies by posting separate questions unless they are very closely related.
Offline lordvader88
« Reply #7 on: January 18, 2018, 07:30:45 pm »
I know that common zeners like a 6.3V 1N4735 ? or whatever, they are 1/2W and need about 44mA going through them to hit the 6.3V (or whatever it is). They are probably bigger then what u said.
1N4728A to 1N4764A
https://www.vishay.com/docs/85816/1n4728a.pdf
That lists all the currents needed for them. 1/2W is sort of big, they get warm/hot.
I'd say just hook them up with a variable resistor and measure the voltage and/or current. I guess the I vs V levels off to flat line.
