Author Topic: How to know which software has created an electrical scheme?  (Read 3993 times)
Offline Kaio MacedoTopic starter
« on: January 09, 2017, 04:53:49 am »
Hello, how to know which software was the creator of a schematic?
Offline BravoV
  • +++ ATH1
Re: How to know which software has created an electrical scheme?
« Reply #1 on: January 09, 2017, 05:23:23 am »
Do you mean this one ? Easy, just use any drawing program.
The following users thanked this post: Kaio Macedo
« Reply #2 on: January 09, 2017, 05:27:20 am »
No. For example: I have a schematic, and I would like to know which software created it, whether it was altium, orcad, etc ...
« Last Edit: January 09, 2017, 09:15:04 am by Kaio Macedo »
Offline BravoV
  • +++ ATH1
« Reply #3 on: January 09, 2017, 05:32:36 am »
No one here I believe can read your mind remotely, as its obvious you don't want to post the exact schematic that you're questioning.
Are you asking people here to "guess" how that schematic looks like ?
Online ataradov
    • Personal site
« Reply #4 on: January 09, 2017, 05:33:05 am »
The only way to know is to know. Post a sample here, there is a good selection of people working with all sorts of software, someone will recognize it.
Alex
« Reply #5 on: January 09, 2017, 05:41:45 am »
It is not a specific scheme, I would like to know how to identify in any scheme.
But I'll post an example>https://drive.google.com/file/d/0BypMuG80jnSOaWp5T3VsRmd5ZzA1aTJPRU5PaXlBTEVQbk80/view
What software created this scheme?
Online ataradov
    • Personal site
« Reply #6 on: January 09, 2017, 05:48:04 am »
Well, this one is easy. It says right in the document properties "Allegro Design Publisher". So this one was created using Cadence tools.
There is no general way to know.
Alex
« Reply #7 on: January 09, 2017, 06:07:25 am »
Thanks for replying, the big problem I encounter is that when viewing the properties of most schemas shows the PDF editor as creator ...
For example: http://www.mediafire.com/file/ow44fapa7kxwuzp/iPhone+6+Plus+Schematic+Full_vietmobile.vn.rar
Because of this, I'm researching a new method to discover the schema creator.
Offline BravoV
  • +++ ATH1
« Reply #8 on: January 09, 2017, 06:32:28 am »
I'm guessing you're so reluctant to reveal the schematic at the 1st place, until you're forced to, as all your examples are stolen schematics.
Just curious what are you planning actually ? To make "modifications" so it looks like the schematic is like untouched/original ?
« Reply #9 on: January 09, 2017, 08:55:03 am »
Just studying, as I mentioned previously, nothing specific.
It may seem simple, but it's important to me.
It has a saying that: Curiosity killed the cat. :)
Online ataradov
    • Personal site
« Reply #10 on: January 09, 2017, 08:59:15 am »
Why? What practical difference does it make what software is used to create schematics?
Alex
« Reply #11 on: January 09, 2017, 09:03:23 am »
I'm studying smartphone schemes.
With this information I could study a specific software.
« Last Edit: January 09, 2017, 09:07:16 am by Kaio Macedo »
Online ataradov
    • Personal site
« Reply #12 on: January 09, 2017, 09:10:36 am »
I don't understand. You can create designs like this in any modern EDA. Just assume that it is Altium and go with that.
Alex
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #13 on: January 09, 2017, 12:36:27 pm »
Simple: obtain a good sampling of output from every single EDA tool in existence.  Examine the design of the output:
- If headers are set, then you probably have the information for free, in plain text.  Example: the Allegro document above.
- If that is unavailable, then examining the output visually may be helpful.  Most tools have distinctive defaults, and most users / organizations don't stray far from the defaults.  Examples: Altium https://www.seventransistorlabs.com/Images/AltiumBufferModel.png (the components are mostly from user libraries, but the shapes of primitives like supply/ground symbols, and the behavior of wires and pins, cannot be changed), Eagle's ugly defaults, OrCAD's relatively small text and odd positioning of it, etc.
Some aspects may be obvious in vector (PDF) format, especially when zoomed in; others may be artifacts of screenshots (like the above picture).  There's an outside chance that you'll see a PDF with an embedded raster image, instead of direct vector format, which can be studied similarly.
- Even if the visual styles are inconclusive, it's very likely the graphical primitives used are distinctive of the output generator that created them.  You would need a PDF decompiler / extractor / dumping tool, and probably, a good knowledge of how PDF itself works.  Some generators will use polylines to draw wires; others, individual line segments.  The line sizes may be magic numbers (Altium only supports four preset line widths, for example).  The segments might be written or draw in raster order, in order of creation, in drawing order, etc.  Components might be drawn as exploded primitives, or linked shapes.  Area fills might be made from flood fills, filled polygons, triangles, line segments, etc.  (Line fill is probably not used with SCH PDF, but some PCB tools use lines to fill polygons, and so the PCB PDF output has lines as well.  PADS does this.)
This identification process will also apply to any other modestly complex output: Gerbers and ODB++, for example.
So, hey, you didn't say how in-depth you wanted to go! ;)  Probably, if you wanted to go this deep, you would've done so already: it's not an easy analysis to perform, but it's an obvious enough route, to someone who truly wants to know the ultimate depths of these things.
Now, if you were simply curious about what created a file, and nothing else, and you absolutely don't want any of this extraneous information... sorry, you can't get to there from here, without going through that!  :-//
Seven Transistor Labs, LLC
