Here is a python script I used to shutdown my raspberry Pi when a GPIO pin changes state. You can easily adapt it I think.
#!/usr/bin/env python
from subprocess import call
import RPi.GPIO as gpio
import os
import time
# Define a function to keep script running
def loop():
while True:
time.sleep(5)
# Define a function to run when an interrupt is called
def shutdown(pin):
os.system("sudo shutdown -h now")
gpio.setmode(gpio.BCM)
gpio.setup(4, gpio.IN)
gpio.add_event_detect(4, gpio.FALLING, callback=shutdown, bouncetime=200)
loop() # Run the loop function to keep script running
