hello everybody,
i found this really nifty trick in the form to measure low resistances accurately with a multimeter, it's called 4-wire measurement or Kelvin sensing, this will be a summery for that, check it first .
Here:
https://www.eevblog.com/forum/testgear/question-11059a-kelvin-probe-set/msg821592/#msg821592it is basically a will known value current source that has also known voltage -low voltage like 2v would be great- connected in series to the resistance you want to measure, and a multimeter connected in parallel to the resister , the meter should be set to the dc voltage measuring rang , it should be ideally set to the mili or micro volt set, but mili volt set work for most time, now measure the voltage drop across the resister.
now it becomes straight forward ohms law:
IR=V
SO,
V/I=R
and because we know the current flow through the resister and we measured the voltage drop across the resister, we use the equation above to get the resistance.
so
example:
