A lot (all ?) of digital oscilloscopes can measure common wave parameters automatically (my rigol gives either few chosen stats or a big table with all of them).
It is low resolution (most scopes are 8-10 bit) but still useful.
Also, your signal generator ( I have SDG1025 so lower series than yours) will automatically calculate output based on what load resistance you select
So it looks like I am limited in that regard. Maybe I should look into Siglent's Bench DMM models.
Even top of the range meters (like agilent 34465A) go to only like 300kHz for truerms. Wrong tool for the job i think.
It would probably be vast overkill for most/all things you're doing. I've got:
* $50 6000 count one (that is at least 7 years old; you can get a whole lot more for $50 bucks now)
* cheapie 2000 count one (which i picked because it has separate power button) for when I need to measure current and voltage at same time
* UT210E because clamp
* 6.5 digit bench one (picotest M3510A)
The vast majority of time I just use my $50 one. It is just more convenient and unless you're doing some analog sensors the extra resolution/accuracy is just not needed.
I only really use my benchtop when:
* I want to measure something over time and dont want to constantly turn meter on and of to take measurement (or leave it on and drain battery)
* When I want to compare something to temperature; that particular one can display measurement of 2 things at once so I can show for example current + voltage or current + thermocouple's temperature
but that's not even something I *need* to do with benchtop, it is mostly convenience (altho I do plan to connect it to some linux box and add data logging at some point) as I could use thermocouple on my handheld DMM
