Can anyone explain what is the great fascination people around here have with looking at the mains power on their oscilloscopes?
I mean, you can safely measure the voltage, with most any decent DMM. And you can look at the waveform through any old wall-wart transformer.
I wonder about that,too,Richard.
On many occasions,I
have used an Oscilloscope probe to look at Mains voltages,basically just to see if they are there.
In this case,the probe earth clip
is not connected to anything (& is probably best removed ) with the return path to Neutral made via the Earth connection included in the 'scope's power cord,&,in turn, the building Earth/Neutral connection.
Obviously,this convoluted return path will affect accuracy of any high frequency transients on the Mains,but it works OK fot troubleshooting purposes.
