Hi all!
I'm about to make a homebrew prototype PCB for something which starts by rectifying AC from a mains transformer. The bridge rectifiers I've got are these GBPC-W packaged ones from RS:
http://docs-europe.electrocomponents.com/webdocs/0dad/0900766b80dadbc1.pdf (<-- link to .pdf datasheet)
There'll be a max current of 3 Amps through it, and I'm probably going to have to have a fan inside the enclosure anyway, so I was hoping to get away with keeping it mounted on the PCB, with its own heatsink on top. My question is: how do I mount it best on the PCB with the heatsink?
I note from the datasheet that it has a hole for a #10 imperial screw, which seems to be as near as dammit 5mm. Should this screw "bite" into the sides of the hole in the rectifier, or fit through it easily?
Also, should the screw be a self-tapper and actually screw through the heatsink & rectifier into a pilot hole in the FR4 PCB, or would this stress and shatter the PCB? Should it pass easily through the PCB and then be tightened with a nut on the bottom?
As you can see, I've no idea, so any help would be greatly appreciated! I was just planning to use a finned heatsink with some compound. Also, if anyone happens to be able to recommend a heatsink from RS for this purpose, that'd be great too, but I'm sure I can find something anyway.
Thanks ever so much for your help.
