Hi
I could run the LWmesh peer to peer application for my atmega256rfr2 devices.
http://www.atmel.com/tools/lightweight_mesh.aspx.Now I modified the code for reducing power consumption in rf devices.The modified code for sending device is as follows
volatile int lastPIRsensorState=1;
volatile int PIRsensorState=0;
void Hibernate(){
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
ADCSRA&=~(1<<7);
sleep_enable();
EICRA|=(1<<ISC00);
EIMSK|=(1<<INT0);
sei();
sleep_disable();
EIMSK&=~(1<<INT0);
cli();
ISR(INT0_vect){
PIRsensorState=!lastPIRsensorState;
static void appDataConf(NWK_DataReq_t *req){
appDataReqBusy=false;
(void)req;
static void appSendData(void){
if (appDataReqBusy)
return;
appDataReqBuffer[0]=PIRsensorState;
appDataReq.dstAddr = 1-APP_ADDR;
appDataReq.dstEndpoint = APP_ENDPOINT;
appDataReq.srcEndpoint = APP_ENDPOINT;
appDataReq.options = NWK_OPT_ENABLE_SECURITY;
appDataReq.data = appDataReqBuffer;
appDataReq.size = 1;
appDataReq.confirm = appDataConf;
NWK_DataReq(&appDataReq);
appDataReqBusy = true;
static void appTimerHandler(SYS_Timer_t *timer)
appSendData();
(void)timer;
static void appInit(void)
NWK_SetAddr(APP_ADDR);
NWK_SetPanId(APP_PANID);
PHY_SetChannel(APP_CHANNEL);
#ifdef PHY_AT86RF212
PHY_SetBand(APP_BAND);
PHY_SetModulation(APP_MODULATION);
#endif
PHY_SetRxState(true);
HAL_BoardInit();
appTimer.interval = APP_FLUSH_TIMER_INTERVAL;
appTimer.mode = SYS_TIMER_INTERVAL_MODE;
appTimer.handler = appTimerHandler;
static void APP_TaskHandler(void)
switch (appState)
case APP_STATE_INITIAL:
appInit();
appSendData();
appState = APP_STATE_IDLE;
} break;
case APP_STATE_IDLE:
break;
default:
break;
int main(void)
SYS_Init();
PORTD=1<<PD0
HAL_UartInit(9600);
while (1)
SYS_TaskHandler();
HAL_UartTaskHandler();
APP_TaskHandler();
lastPIRsensorState=PIRsensorState;
Hibernate();
The device communication works well when the Hibernate() function is not called.But when this function is called it enters into a deep sleep and communicate seldom .dis sleep mode affect rf communication?What is the mistake in my code please help.
