I once worked in an manufacturing plant that used ferric chloride for etching. It was supplied from a room with chemical resistant cement on the floor, plastic drain covers, solid PTFE pumps, plastic drums, and every precaution taken in the handling of it. In spite of that, the ferric chloride pumping stations soon looked like the messiest, most stained, ugliest area you could imagine.
Ferric chloride is bad news. There are no circumstances you should bring it inside the house.
