Hi Everyone,
I'm thinking of making a ht1632c based display using the ltp-305's from digikey/mouser that are a 5x7 matrix with decimal point. I like these displays because they are somewhat old style with led's shaped in a matrix encased in plastic. This is a for fun project. Because of the way the ht1632c multiplexes I'm going to use 24x16 mode which allows me to drive 8 digits, 4 wide (6 columns each) x 2 rows (14 rows). 3mA average for each dot is fine, so the pulse for each of the 24 will be 3mA*16 or 48mA. 0.048*24 leds is 1.152A, so it might go from needing 1.152A for all led's on and 0A for all led's off. In practice, I plan to use a standard 5x7 character set which will typically not involve all being on at the same time. How do I size a capacitor for the display board that can handle this?
Thanks,
Alan
