Author Topic: How to test an N-Channel MOSFET??  (Read 4963 times)
Offline AzharTopic starter
    • Youtube Channel
« on: July 20, 2014, 01:20:11 pm »
I have an LED TV which is dead. The main component in the power supply board is the MDF7N60B which is an N-Channel MOSFET, I suspect it is the cause of the TV being dead, I already removed this component, but I am not sure how to test it!
is there a way to test it with a DMM?  :-DMM
Can I replace this MDF7N60B with any other equivalent component?
Thank you in advance!
MDF7N60B datasheet:
http://www.datasheet-pdf.com/datasheet-html/M/D/F/MDF7N60B-MagnaChip.pdf.html
Offline mij59
Re: How to test an N-Channel MOSFET??
« Reply #1 on: July 20, 2014, 01:27:07 pm »
Please take a look at this video.
No its better to replace with the same mosfet.
Offline Neilm
« Reply #2 on: July 20, 2014, 08:41:05 pm »
First thing I do is check to is if there is a short between any of the pins.
There are many factors that go into choosing a FET for a particular application. On resistance, off resistance, max peak current, max steady state current, max voltage, gate charge and others. If you have to replace a FET with a different one all these have to be taken into consideration. That requires an understanding of why that particular component was chosen. "Better" values might lead to unintended consequences.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
