Hi all
is there a way to check if the IC work or not ?
because when I apply 12V to the IC and 5V to HIN and inverter one to LIN the output remains high for both mosfet
this is the circuit from datasheet
I used normal rectifier diode, 22uF 50V capacitor between Vb and Vs and 100Ohm resistor for the gate of the MOSFET
please help
regards
