Author Topic: how to test TSOP 1738  (Read 2710 times)
Offline manjunathTopic starter
« on: July 31, 2014, 11:57:34 am »
Hi all,
      i tried to test TSOP 1738 using connection as shown in attachment but i didnt get output voltage. can anyone help me to solve this
Offline VK5RC
Re: how to test TSOP 1738
« Reply #1 on: July 31, 2014, 12:07:14 pm »
A quick look at the data sheet has a >10k resistor between 'Out' and Vs to pull it up, the data sheet comments 'out' should not be left 'low'.
this may be a starting point, others I am sure will help.
Offline Asim
« Reply #2 on: July 31, 2014, 12:22:08 pm »
The moment I read your post, I walked away of the PC, got a tsop1738, connected it as shown and tested the receiver with an oscilloscope to make sure it works, then tested it with a multimeter.
 first of all measure the output voltage WITHOUT pressing any button on your TV remote, it should be 5V.
Secondly, when a button is pressed( keep holding the button), the receiver output will go down and up at 38KHz( you can see this if you have an oscilloscope), which will result in an output voltage drop at the output ( mine shows 4.4V)
Offline amyk
« Reply #3 on: July 31, 2014, 10:07:19 pm »
I can't be the only one who thought "a 1738-pin TSOP...? What?" :o
