Hi!
I'm looking to build a small arduino based (maybe mbed system) pressure sensor+LCD display, and am deciding on what pressure sensor to start the project with.
I need to read a range of approx 0-30psi (0-200kpa) and these pressure sensors are cheap on RS.
I want to keep the project simple, and understand this sensor needs a 0-10V power input, but I cannot understand what output range the sensor has?
More expensive sensors are quite clear that they are 0-100mv output, so easy to build the rest of the design around.
But I want it to be cheap
So looking to understand the cheap sensors first.
Datasheet:
http://docs-europe.electrocomponents.com/webdocs/0ef4/0900766b80ef4279.pdf RS link:
http://uk.rs-online.com/web/p/pressure-sensors/7191156/ Many thanks!
