Author Topic: how to use interruptions for rotary encoder on pic16f886 for C language  (Read 1182 times)
Offline little_carlosTopic starter
Hello, i need to use a rotary encoder to control pwm output on pic16f886 on C language (mikroC), why i need interruptions? because the pic has to manage 2 analog readings and 1 lcd displaying data at the same time, so reading the encoder without interruptions just doesnt work. the problem i have is that i dont know how to manage to read the encoder using interrupts, can you give me any idea of what instruction should use to have proper readings? the encoder is one of those "digital potentiometers" or pot-like encoders, has 2 outputs. Thanks for your time
Offline android
« Reply #1 on: January 23, 2017, 08:47:34 pm »
Lecturer: "There is no language in which a double positive implies a negative."
Student:  "Yeah...right."
