Ladies & Gents, Boys & Girls...
Many thanks for all the suggestions.
Alas the Lister Petter AD1 engine is being very naughty and not playing ball (low compression), and I've run out of time and talent. My mechanical knowledge is as poor as my electronics obviously, and now it's down to stripping down and regrinding valves/pistons etc.
I bought it with an Air Compressor head attached to drive a Shot Blaster so it was a means to an end. I then thought to take off the Compressor and put a GenSet on and continue to use it (possibly switching the Compressor head back in for occasional future use).
I will persevere with it but with winter coming and time against us its time to just hire in a Compressor and crack on with the main project so this aspect will have to be parked for a few months :-(
Having said that, the thought process of 'measuring RPMs' in a simple diesel engine was valuable and directly transferable to the main marine engine. Plus I have hopes in the future for the little AD1 (if not this one, another) with more time, effort and a little cash.
For the AD1 it looks like the teeth of the Gear Ring is the way forward (or the flywheel, which has one cut out on its outer edge), not all AD1 have Gear Rings but at least this one does.
Many thanks for all the help/assistance. Special shout out to G7PSK who has gone the extra mile with much advice via e-mail/PM.
No doubt Greg and myself will be back to pick your collective brains with regard to other aspects of this project in due course. I know there has been some flaming of attitudes in this 'Beginners' Forum but you've been fantastic to Greg & myself... which is nice ;-)
o7
@ Anks... no alternator
@FCB... Agreed. Didn't know what they were called nor the pro's/con's compared to other methods.
