Author Topic: howland integrator  (Read 1847 times)
Offline ArjunSukumarTopic starter
  • Country: in
howland integrator
« on: October 10, 2015, 05:58:11 am »
Hi guys,
I want to generate  a sawtooth waveform using an Howland integrator or de boo integrator. I don't know how to proceed with the design. Suggest me any video lectures links or text books which describes the working and design steps
Thanks in advance
ARJUN SUKUMAR
Offline LvW
Re: howland integrator
« Reply #1 on: October 10, 2015, 03:50:19 pm »
Hi guys,
Thanks in advance
OK - here is the desription of a DEBOO integrator (based on a Negative Impedance Converter - NIC):
* Take a simple RC first order passive lowpass; time constant T=RC.
* Connect the pos. input node of a non-inverting opamp stage (gain G=1+RN/RL) to this RC lowpass.
* Place another resistor RP between opamp output and pos. input node.
* Make RP*RL/RN=R
* Result: The negative input resistance of the NIC (at the pos. input) Rin=-RP*RL/RN compensates the damping properties of R.
* Integrating function: H(s)=G/sT
* Attention: When this integrator is used as a stand-alone unit (and not within a stabilizing negative overall loop), the ratio RL/RN must be selected slightly larger than R/RP to ensure a stable DC operating point.
« Last Edit: October 10, 2015, 04:08:47 pm by LvW »
