You are 'earthed', not ´grounded'. Depending on your shoes, clothes, you potential is sufficient to polarize the transistor base. So it conducts but then, as retrolefty says, as there is no current limiting device, I suspect that your Nokia charger has too much current to source and maybe it's it which cuts power. And then the system recycles...
