Author Topic: I got an ocilloscope, Now what?  (Read 15555 times)
Offline xwarp
Re: I got an ocilloscope, Now what?
« Reply #25 on: May 18, 2014, 09:26:28 pm »
I tried Craigslist but it reminded me of E14. |O
Too many things to click on.....
What exactly do you mean?
Craigslist isn't a site where you just search one time. If something doesn't show up, that doesn't mean that it won't ever.
You have to keep looking.
For example, if happen to want another meter, enter "multimeter", "dvm", or just a brand name.
Don't be specific with the terms as that will limit your search, not to mention, there are times when people will post things with incorrect titles or info because they just don't know what they are selling, they just want to get rid of it.
ETA:
How about swap meets, flea markets, etc, around you?
« Last Edit: May 18, 2014, 09:30:58 pm by xwarp »
Offline jetmorgan
« Reply #26 on: May 19, 2014, 01:24:41 am »
An easy and fun experiment you can do is to use your scope to look at switch bounce. Hook up one side of a toggle switch to 5 volts, and the other side of the switch to a resistor, the the other side of the resister to ground.  Put your scope probe on the switch side that's connected to the resistor and flip the switch back and forth to see how the switch contacts "bounce"  This exercise will teach you how to use the horizontal time per division knob and the volts per division control.  I've made a really simple video you can watch to get an idea of what you will see. The link is
Have fun with your scope! They are an extremely important tool for electronics work.
Offline FrankenPC
« Reply #27 on: May 19, 2014, 04:36:05 am »
I believe he has an analog scope.
Chinglish poetry: In the hot summer. In the car ran full steam. It tastes strange. For this worry? With this fan will bring you a cool summer. Suitable for all kinds of cars. Agricultural vehicles. Van. Tricycle.
Offline TVmanTopic starter
  • Life is A bunch of people staring at computers. ;)
« Reply #28 on: May 19, 2014, 03:27:03 pm »
Yes it is an analog scope that I own.
« Last Edit: May 19, 2014, 03:29:40 pm by TVman »
Yeah, I play Minecraft!
But I'm on here more because I learn more. :D
Offline David Aurora
« Reply #29 on: May 21, 2014, 02:41:55 am »
The next thing you wish you had while working on a project.
This. A thousand times this.
« Reply #30 on: May 21, 2014, 03:31:16 am »
What do you mean? :-//
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #31 on: May 21, 2014, 03:53:40 am »
You buy stuff when you need it.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
« Reply #32 on: May 21, 2014, 03:59:48 am »
Offline electrophiliate
  • Eternal Novice
« Reply #33 on: May 21, 2014, 04:54:20 am »
Hi TVman. I don't know how much you know already, and I'm not an expert either, but here are some basic suggestions ...
1) Don't attempt to measure the waveform of the mains power (unless you know exactly what you are doing and have the right equipment e.g. high voltage differential probe).
2) Watch this video about scope grounding [EEVblog #279 - How NOT To Blow Up Your Oscilloscope!]:
3) Watch this video too [NJARC Oscilloscope School a.k.a. "Scopes For Dopes"]  (it's long but worth it, especially since you have an older analogue scope).
Others have already made some suggestions about probing simple circuits.
If you have a signal generator or even just a 555 timer in astable mode, you could play around with measuring capacitance and inductance:
Hope that helps, and good luck!
« Last Edit: May 21, 2014, 05:01:26 am by electrophiliate »
Nothing is quite like a great humming power-station.
« Reply #34 on: May 21, 2014, 05:01:47 am »
Hmm looks good :D
Don't know when I can watch it though. :P
Offline Stonent
« Reply #35 on: May 21, 2014, 04:38:34 pm »
Hmm looks good :D
Any videos by W2AEW are really good to watch.
« Reply #36 on: May 21, 2014, 05:55:04 pm »
Hmm looks good :D
Oh yes, Alan makes great educational videos. ^-^
Good job Alan! :-+
Offline M0BSW
  • Left this site 2013, they will not delete it ????
« Reply #37 on: May 21, 2014, 07:49:28 pm »
This would be a nice simple generator to build.
no one would or will tell me how to delete this account
Offline madshaman
  • ego trans insani
« Reply #38 on: May 21, 2014, 08:16:50 pm »
I'd say build yourself a triple output bench supply :-)
To be responsible, but never to let fear stop the imagination.
« Reply #39 on: May 22, 2014, 12:33:53 am »
I'm thinking of building a FG and a Psu. :D
« Last Edit: May 22, 2014, 03:33:42 am by TVman »
Offline Rigby
  • Learning, very new at this. Righteous Asshole, too
« Reply #40 on: May 22, 2014, 02:07:56 am »
Both are excellent beginner projects.  Before you build a PSU, you'll need a load to test it with. Also a good project. You'll need a PSU to test the load though... Wonder which came first?
Offline rs20
« Reply #41 on: May 22, 2014, 02:34:02 am »
Ok?
Just in case you haven't understood this yet:
Saying "I have an oscilloscope, what tool should I buy next" is, perhaps, the wrong question to ask. You should be thinking about which projects to work on next. As you're working on/preparing for those projects, you'll find yourself thinking:
-- "I need to input a signal into this circuit to test it". OK then, buy a signal gen.
-- "I can't power this circuit!". OK then, buy a PSU.
-- "I can't analyse the timing issues on my PCIe circuit!". OK then, buy a 40 GHz $100,000 oscilloscope, then.
For example, I like working on a lot of digital stuff, so I've never had a signal genenerator. On the other hand, I program Atmel micros a lot, so I splurged on an Atmel Programmer/Debugger. My neighbour might be the opposite, he might well be far better off with a signal gen than a debugger.
The point is, no-one can tell you what tools you should have until you find out what's holding you back from doing the projects that interest and excite you. Wait until you're frustrated by not having something, and then buy it.
« Reply #42 on: May 22, 2014, 03:20:45 am »
Ok,
I was looking on eBay today and found this.... :P
http://www.ebay.com/itm/15V-2A-NEW-Precision-Adjustable-Variable-Power-Supply-PS-1502DD-ship-from-US-/331209348058?pt=LH_DefaultDomain_0&hash=item4d1d9d93da
Or Does anyone in the US have a PSU to sell for a good price or to give away? :-//
Oh, and xwarp is searching through his junk to to sell to me some stuff.... ^-^
So far he gathered a HP 6215a 0-30v 400MA supply.
Thanks,
Hunor :D
« Last Edit: May 22, 2014, 03:25:07 am by TVman »
Offline Rigby
« Reply #43 on: May 22, 2014, 07:36:47 pm »
What state to you live in?
« Reply #44 on: May 22, 2014, 07:38:25 pm »
Can I Pm you this?
Offline Rigby
« Reply #45 on: May 22, 2014, 07:41:04 pm »
Can I Pm you this?
yeah of course
« Reply #46 on: May 22, 2014, 07:42:25 pm »
PM sent! :D
Offline w2aew
    • My YouTube Channel
« Reply #47 on: May 22, 2014, 09:30:20 pm »
Ok,
Thanks,
Hunor :D
for what it's worth, I have  a few of those little 6200 series analog supplies.  I love 'em and use them all of the time.  They are my main bench supplies.  I'm a big fan of *measuring* the voltage at the load rather than relying on what the display on the supply says, so I actually prefer the analog metering on my bench supplies.
FAE for Tektronix
« Reply #48 on: May 22, 2014, 09:42:19 pm »
Ok,
Thanks,
Hunor :D
Really? how much? :o
For what it's worth?
Dunno? :-//
« Last Edit: May 23, 2014, 03:34:53 am by TVman »
Offline Dave
  • Country: si
« Reply #49 on: May 23, 2014, 12:57:03 am »
I don't think he was offering to sell them to you. I think he just wanted to let you know that these are good power supplies and you should consider buying one. ;D
