Hi there boys and girls,
This is my first post here and i have come for your advice..
I bought the 998D soldering station from ebay.
I wont be using this unit day in day out just the occasional job here and there..
I received the item today and kinda shocked what i found inside..
I was just wondering what use guys advice me to do or recommend.
Or If someone here may of owned one of these and what they did..
So My question is, Would i be ok to ground/earth the unit to the case from the crimp that is attached to the laminations on the transformer, I obviously should ground the case,
But i wanted to hear from you all what should i do to make this unit safe to use thank you
Here are some pics i have fixed the hot air earth already
https://imgur.com/a/9n3g4Wb
