I tried testing for continuity, but the beeper in the multimeter would turn on and off like 4 times a second. It wasn't an overload, I'm sure. Must be some residual voltage playing up on me.
Now the only thing that remains is the color mess we have in the service panel. I think tomorrow a real electrician is coming over to check the grounding issue with the heater, but I would like him to check if everything related to electricity is OK because I have lots of concerns. For starters, there's a power inverter wired in a dangerous way, the service box is floating, certain cable's gauge seem too small for the circuit breaker capacity (I saw 60A breakers used with gauge 10 wire, should be 6), split phase 240V outlets might be unfused and with 1 line wired to the power inverter and finally, the color coding (I'm sure that will never get fixed, though
This is electric hell
I don't even want to touch it, such a mess.
