These are the cheap 1602 LCDs with the blue background that you can get from Amazon - 1602A V2.0
Any pointers to what I am potentially doing wrong or what the issue is would be gratefully received.
I am running a ATMEGA328P at 3.3V on a breadboard along with some other sensors DH11, RTC etc. I am using the LCD1602A as the display for the time, temp and humidity. The 1602 display is running from 5V suppied from a 7805 and the rest of the circuit is powered by a 3V3 reg. The 1602 data lines are driven directly from the ATMEGA at 3V3. There are numerous decoupling capacitors spread around the circuit
Issue: Over the course a day or so the LCD display starts to corrupt and eventually the 1602 blows going short circuit taking out the 7805 reg. This has now happened three times
Each time the LCD blowing has coincided with me prodding around with my oscilloscope looking at the output of the DH11 and RTC and after three times it is more than a coincidence. Could the Oscilliscope be introducing a spike big enough to blow the 1602?
