For a learning project, I'm going to build some circuits to make use of scavenged 18650 LiIon cells. One of the circuits I need is a charger for 3-4 cells in series. I'd like to find an IC that does most of the heavy lifting for me.
I'm prepared to do a lot of research digging through specs on manufacturer sites to find good candidates, but, I'd like to avoid doing a lot of work that isn't likely to go anywhere.
In particular, I get the sense that it is hard to get ahold of components from some manufacturers in hobbyist quantities at reasonable prices. Is this something that is worth worrying about?
The other thing is that I'm willing to work with surface mount devices, provided the have edge connectors. Are some manufacturers more likely to have hobbyist friendly packaging options?
For both of the above questions which IC manufacturers are likely to lead to disappointment? Which are likely to bring me joy?
The list I'm starting with: Linear Devices, Microchip, TI, Atmel, STMicro, Cypress, Maxim.
If people have specific ICs, or product lines to recommend, I'd appreciate that too, but at this point I'd like to cast a reasonably wide net and then prioritize from there.
Thanks in advance for your advice!
