Hello,
My first post here. I need some help with an ICM7555 Timer in Astable mode.
I'm working my way through "Learning the Art of Electronics - 3rd Ed" in order to keep my brain from going to mush in retirement
I'm now on the chapter that introduces the 555 timer, I have no problem with the theory but I'm getting a strange result when I build the circuit on a breadboard. - I'm sure it is something I'm missing but I can't see it.
The circuit is the timer in astable mode, Fig 8L.8 page 341 for those with a copy of Learning the AOL (or Fig L10.5 P236 in the 2nd Ed. - Silver cover)
When I work out the frequency of the o/p I get 480 Hz. (f=1.44/(Ra + 2Rb)C, Ra and Rb are 10k, C is 0.1uF)
When I use LT Spice I get 480 Hz., same as the math.
On the breadboard the circuit runs at 846 Hz. I checked this on a modern scope (R&S HMO 3034), on an old Tektronix 2225, and even on a DMM. They all say 846Hz. approx.
I'm sure I'm using the correct component values. I've changed the ICM7555 for an LM555 with the same result.
The duty cycle is correct, and Vdd is at +15V as per the AOE book.
Anyone got any ideas why the frequency is so different in reality, I've run out of ideas?
Happy to post Spice and scope screenshots if needed.
Many thanks for any help.
Rod
