I was looking to have a go at building an ideal diode bridge, using the LT4320 and N channel mosfets. My idea was to bread board it first to get it laid out right. There is a couple of things I'm unsure of, i am going to use a dip package. I'm unsure on the mosfet rating, i know i want a working current of 15 Amps maximum, but typically 10 Amps continuous current. I was looking at the IRF540 mosfets, but not sure if these are suitable. Another thing I'm unsure of is cooling of the mosfets, and if heatsinks are required. My input voltage would be 14.80 Volts AC, and I'm using an LM2940CT-12 low drop out voltage regulator. Any advise on the ideal diode bridge appreciated.
