Hi, can anyone help me identify the component in the attached pic and what it is for?
It is part of a small battery pack (3 x AA cells in series) and it connects to the negative terminal of the pack and then to the white pin of the battery pack connector. Of the other two pins of the connector, the red one is connected to the positive terminal of the pack (obviously!) and the black direct to the negative terminal. I don't understand the point of this or what it is even!
I couldn't measure any resistance with a cheap multimeter, seemed to be open circuit. Also didn't seem to be a diode when checked with the meter, I may be wrong.
Any help appreciated!
