Author Topic: Identify this connector  (Read 1981 times)
Offline MukrakiishTopic starter
« on: May 08, 2017, 04:57:31 pm »
You know how it can be when your searching for something but don't know the exact term to find the component you need (like in Digikeys fortress of parts).
Picture here, the little BNC splitter used in this fellows setup.
Figured one of you would know what this thing is called. I don't have such a handy thing on my bench just yet and would like to have one (using my BNC -> Gator clips and other related goods don't play nice with my Freq Gen to Scope connection).
Offline electr_peter
  • Country: lt
Re: Identify this connector
« Reply #1 on: May 08, 2017, 05:12:02 pm »
Try searching for "BNC to banana adapter". There are few configurations versions (female/male).
Offline stj
« Reply #2 on: May 08, 2017, 05:13:38 pm »
or BNC to 4mm jacks
Offline KD0CAC John
« Reply #3 on: May 08, 2017, 05:19:39 pm »
Picture B with the circle , has an extra piece in it - but the picture is not big enough to tell what is there .
Besides the BNC - banana adapter , so with the circle in the B picture - that is what figure your asking about , so need a better picture ?
« Reply #4 on: May 08, 2017, 05:55:51 pm »
In the second picture is a small SMD inductor that he is measuring (it's from a "how to identify unknown inductors" page).
Thanks you guys for that, that makes so much sense now that you write it out. Should have known :P
Offline Neomys Sapiens
« Reply #5 on: May 08, 2017, 07:43:18 pm »
If you need the type which does not only accept 4mm plugs, but which can connect single wires by screw-down, they often are listed as 'BNC-to-Binding Post' adaptors.
Offline tablatronix
« Reply #6 on: May 08, 2017, 09:11:20 pm »
« Last Edit: May 08, 2017, 09:15:21 pm by tablatronix »
Offline Fraser
« Reply #7 on: May 08, 2017, 09:57:59 pm »
I have some of the exact types pictured, with the offset ground connection socket. They are Philips part PM9051
Fraser
