If you are a beginner, go to your local ham meetups, get familiar with which tools the other members use, and once your familiar with them, you can better define what will suite your needs.
any of us saying to get a 100Mhz rigol, while good for an electronics beginner may not meet the same criteria as for Ham activities such as tuning filters, and following modulation / demodulation paths. this is more the role of a spectrum analyser, but these still tend to cost significantly more than beginner level scopes.
Oscilloscope FFT displays of spectrum may get you by, but i personally have not even got a DSO, nor do I do ham activities, so I cannot answer with your limited requirements
The best thing you can do to get a solid answer is spec out what you need to measure, with this knowledge, people without ham experience can then chime in.
