Hello
Normal 50 ohms receiver like spectrum analyzer is also useful in 75 ohms system with help of matching pads on its input.
In case of transmitter like signal generator is it possible to use same i.e. to feed signal from 50 ohms generator to 75 ohms system under test (receiver).
For these two applications required same pad or different pad?
Thank you.
