Hello,
I am using AD623 instrumentation amplifier for the load cell output signal conditioning.
The signal is constantly drifting by a very small amount, which makes hard to set reference values for the calculations in the software.
Firstly I was assuming that the temperature is the only cause, as it makes the biggest difference in the readings. But even keeping the load cell constant temperature I get a drift.
One friend, who has more experience with electronics suggested that that might be due to the fact that I am using single supply for the AD623 in-amp.
I wonder if swapping to the dual supply and even swaping in amp to AD620 help if not to solve, at least to reduce the drift problem? I used the reference circuit from AD623, datasheet p.17, fig45 for the circuit.
Cheers
