Author Topic: In Common emitter Circuit - higher amplification  (Read 2550 times)
Offline ulixTopic starter
« on: December 20, 2015, 11:37:24 pm »
I was just wondering, which transitor npn or pnp has a higher amplification in the common emitter circuit?
I would say, it's the npn type, but how can I prove this? :wtf:
cheers
Offline langwadt
Re: In Common emitter Circuit - higher amplification
« Reply #1 on: December 21, 2015, 12:04:19 am »
cheers
why would the amplification be different just because you flip it upside down?
« Reply #2 on: December 21, 2015, 12:12:28 am »
npn to pnp doesn't mean flipping!? it's a diffrent transitor.
Offline Marco
« Reply #3 on: December 21, 2015, 12:26:33 am »
If it's degenerated sufficiently the amplification depends on the ratio of the emitter and collector resistors.
If it's not degenerated and at sufficiently low frequencies the AC amplification is purely a function of biasing, it is independent of NPN/PNP or even device material. This is because gm is purely a function of Ic, see page 24 of this class handout. I did not know this part before googling.
PS. the only time I see non degenerated common emitter amplifiers is in RF circuits.
« Last Edit: December 21, 2015, 12:28:22 am by Marco »
Online vk6zgo
« Reply #4 on: December 21, 2015, 12:29:50 am »
If it was 1964,the standard answer would be "an NPN",but,over the years,PNPs have improved,due to better manufacturing processes,till there is no real difference.
There are still more NPNs around,though.
Offline dom0
« Reply #5 on: December 21, 2015, 12:39:53 am »
The fundamental difference between hole and electron mobility is still there, and a few in-silicon processes are different, too. So you still don't get identical transistors just by flipping N and P.
That being said the common emitter circuit will behave similar for transistors with similar key specs (fT, miller capacitance, beta), independent of NPN or PNP. Of course, finding RF PNPs tends to be not as easy as coming up with a NPN.
Correct. Although, as you mention, too, it is only true for low frequencies, where the Miller effect may be neglected. However, the equation Rbe = Ut / Ic is still a very important one in many fields, e.g. linear supply design, AF amplifiers etc. and often disregarded (with corresponding, i.e. bad, results).
« Last Edit: December 21, 2015, 12:42:35 am by dom0 »
« Reply #6 on: December 21, 2015, 12:58:02 am »
Both should have the same dimensions...
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #7 on: December 21, 2015, 02:28:30 pm »
Complementary PNP are about 10% worse (mainly as hfe with respect to frequency, and Vce(sat)), but this is much less than the >40% difference in a single part (regardless NPN or PNP) due to manufacture and temperature variations.  If your circuit will fail due to this difference, it's a textbook Bad Circuit.
Seven Transistor Labs, LLC
