Author Topic: SIM800 TCP/IP init code using Arduino Mega  (Read 671 times)
Offline Vindhyachal.takniki
« on: October 12, 2016, 03:39:37 pm »
1. I have to write SIM800 TCP/IP code using mega2560. Earlier I was trying to use seeeduino library on my locally purchased SIM800. It has three pins Rx, Tx & Gnd as output.
2. Somehow seeeduino was not working on this although I had disabled the pin status section & rx & tx were as mentioned in seeeduino library. I must be making some mistake. SO I left it & wrote own code.
3. Below is my code to initialize TCP/IP before sending data. I took reference from seeeduino library.
4. Checked the code on console giving correct response. IS below code ok? Anu correction required. Any command missong?
5. One problem I have currently is that while reading for response from SIM800, I wait for complete timeout period. Like if I have 5000 millisecond timeout then wait till 5 sec & read as much data is available. How can I shift the code such that as soon as correct response comes, code should break.
void sim800_clean_buffer(char *buffer, uint8_t count);
void sim800_read_buffer(char *buf, uint8_t count , uint16_t timeout);
int8_t sim800_send_cmd_and_wait_for_response(const char* cmd, const char *resp, unsigned int timeout);
int8_t sim800_wait_for_resp(const char *resp, unsigned int timeout);
void setup()
/* init serial port for msg */
    Serial.begin(9600);
/* init serial port for sending data to SIM800 */
    Serial1.begin(9600);
void loop()
    char ipAddr[33];
    int8_t idx;
    uint8_t init_again;
/* Start connection */
    Serial.println("GPRS - TCP Connection Test...");
/* basis command must be cleared */
    while(0 != sim800_send_cmd_and_wait_for_response("AT\r\n" , "OK" , 5000U));
    while(0 != sim800_send_cmd_and_wait_for_response("ATE1\r\n" , "OK" , 5000U));
/* full functioanlity */
    while(0 != sim800_send_cmd_and_wait_for_response("AT+CFUN=1\r\n" , "OK" , 5000U));
/* SIM status */
    while(0 != sim800_send_cmd_and_wait_for_response("AT+CPIN?\r\n" , "+CPIN: READY" , 5000U));
/* GPRS service status */
    while(0 != sim800_send_cmd_and_wait_for_response("AT+CGATT?\r\n" , "+CGATT: 1" , 5000U));
/* check if already registerd */
    sim800_clean_buffer(ipAddr , 33);        /* fill array with null */
    Serial1.write("AT+CIFSR\r\n");           /* get local IP address assigned */
    sim800_read_buffer(ipAddr , 32 , 5000);  /* read the loack IP in a aray */
    ipAddr[32] = '\0';                       /* make sure array is null termianted since next it will be converted into string */
    String str(ipAddr);                      /* convert array into string */
    Serial.println(str);
    Serial.println(str.length());
    idx = str.indexOf("ERROR");              /* if ERROR is received then if have to register SIM800 again otherwise it is already registerd */
    if(idx >= 0)
        init_again = 1U;
    else
        init_again = 0U;
    if(1U == init_again)
    /* Join gprs */
        while(0 != sim800_send_cmd_and_wait_for_response("AT+CSTT=\"airtelgprs.com\",\"\",\"\"\r\n" , "OK" , 5000U));
        while(0 != sim800_send_cmd_and_wait_for_response("AT+CIICR\r\n" , "OK" , 5000U));
        while(0 != sim800_send_cmd_and_wait_for_response("AT+CIFSR\r\n" , "." , 5000U));    /* "." for since IP address will have "." */
    delay(1000);
    for(uint8_t i = 0; i < count; i++)
        buffer[i] = '\0';
    unsigned long timerStart;
    unsigned long timerEnd;
    uint8_t i = 0U;
    timerStart = millis();
    while(1)
        if(Serial1.available())
            if(i < count)
                buf[i++] = Serial1.read();
            else
                break;
        timerEnd = millis();
        if((timerEnd - timerStart) > timeout)
            break;
/* flush data */
    while(Serial1.available())
        (void)Serial1.read();
    Serial1.write(cmd);
    return sim800_wait_for_resp(resp , timeout);
    char rx_str[51];
    uint8_t cnt;
    int8_t idx;
    for(cnt = 0U ; cnt < 51U ; cnt++)
        rx_str[cnt] = '\0';
    cnt = 0U;
    while(1)
            if(cnt < 50U)
                rx_str[cnt] = Serial1.read();
                cnt++;
            break;
    rx_str[50] = '\0';
/* flush data */
    String str(rx_str);
    idx = str.indexOf(resp);
    if(idx >= 0)
        return 0;
    else
        return -1;
