The kit in question(link)I have seen this kit referenced once or twice on the board. While going with something like this deprives the need for a newb, like myself, to wade through the process of designing one. The low cost for such a fundamental tool is too good to pass up. (All my "fun" money I cant help but spend on my son, hehe) A quick glance at the kit makes it obvious to me that it is begging to be modified/upgraded. Hooking in a few panel meters, banana plugs for output, proper grounding connection, and jumper connections on the pots is a no brainer. As is adding a fuze and replacing the single turn pots with multiturn for precision control.
I am not so confident in my other observations. (Or maybe I am just overthinking a bit
) So any guidance is greatly appreciated. For example: I may be reading the board wrong, but is it missing output protection diodes? Wouldn't it be a good idea to replace the 1/4w resistors with higher wattage equivalents for better heat tolerance and stability? Adding an additional filter cap in parallel (and replacing it with a real brand)? Adding a thermistor for overheating protection? Separate switch to turn output on/off?
Even with the proposed modifications, it seems to me, would make a very nice and compact bench supply if put in an enclosure. Anyone think maybe there are other mods/upgrades that would be appropriate that I overlooked?
