All I know there is a control unit above ground has 4mhz crystal, a microchip and few more components, and from there 2 wires go underground and on a end is a coil ( no ferrite, 500 winding, 29-30GA ) witch will transmit a 512HZ signal. Can you please help me with the simple circuit diagram. Thank you.
The same sonde used mostly by plumbers, to get the location of the problem in a sewer or drain lines
