I can confirm your working is correct, but as mentioned you have left the integral sign in your (working/)solution. They, the marker, might be a bit forgiving in an exam but as this is an assignment, I would assume you would be deducted marks for this. At least, this is how it worked for me when I did math assignments.
As for part b, you use the same substitution but as you're now doing a definite integral you need to be cautious of what the integral limits will become once you do the substitution. You also need to do a second sub. for the integrand 1/(x+1) which will also give different upper and lower limits (differing from the given -0.5 to +0.5).
My best advice is to just be careful with your upper and lower limits when doing U-substitution. Otherwise, the integration is trivial.
