Author Topic: Interesting DIY kits to purchase/experiment with?  (Read 5097 times)
Offline silenterTopic starter
« on: February 18, 2018, 06:21:56 pm »
Hi everyone. Just a vague question, and I hope I didn't select the wrong forum. Briefly:
Do you have any interesting DIY kits (found on ebay/aliexpress/etc) that you would recommend for either fun or experimentation?
I bought some very cheap kits early on, mainly to practice soldering and to look at simple working circuits.
One kit that stuck with me was the little "GM328 transistor tester", of which you can find 20 variants online. Although I now have much better instruments, I cannot count how many times I pulled this little thing out, and for most purposes it still serves me nicely today. I upgraded the crystal, modified the board, and even hacked the firmware to tweak the behavior to my liking. If I had to point a beginner to something to have fun with, this would definitely be something I'd recommend, both for the usefulness and learning experience you can get out of it.
Is anything else that you would recommend, even just for the fun of it?
Offline rstofer
Re: Interesting DIY kits to purchase/experiment with?
« Reply #1 on: February 18, 2018, 06:29:31 pm »
FG085 Function Generator (if you don't already have a signal generator)
https://www.sparkfun.com/products/11394
Offline Jwillis
« Reply #2 on: February 18, 2018, 06:43:53 pm »
The  JYETech DSO138 DIY Digital Oscilloscope Kit is pretty cool. That can be found on ebay .Since its open source even the knock offs aren't bad.
Offline HecticZA
« Reply #3 on: February 18, 2018, 06:47:18 pm »
This is something that I'm planning to get in to.
Sort of interested in the oscilloscope kits, mostly because it is unlikely that I will be able to buy any scopes in the next few years.
The fact that Dave don't like those kits have put me off though.
I've never used a scope though and I'm still thinking of buying the kit just to get some experience with it.
Sent from my SM-N950F using Tapatalk
Offline Peabody
« Reply #4 on: February 18, 2018, 07:02:06 pm »
I would raise the JYETech entry to the DSO150.  Buy a genuine one from Banggood for about $21.  Also buy their scope probe and a 9V power supply. Another $10-12 for that stuff.  And then when you're all done you can think about converting it to battery power (there's room in the case) - see pic.
Get the kit version that has all the surface mount stuff pre-installed.  It's actually cheaper for some reason.
I know Dave thinks these are rubbish.  But I've actually found mine to be quite useful.  And it's a fun kit to build.  But you do want to be sure you get a genuine one.  You can't do the latest firmware updates otherwise.  Yes, they do firmware updates.  $21.  Who would believe it.  Buy it from Banggood - they are genuine.
if you do get that one, ask me about alternate mounting of the rotary encoder.
« Last Edit: February 18, 2018, 07:04:25 pm by Peabody »
The following users thanked this post: mixiom
Offline HecticZA
« Reply #5 on: February 18, 2018, 07:16:37 pm »
Thx for the info.
Offline Jwillis
« Reply #6 on: February 18, 2018, 07:25:57 pm »
If your just starting out like me keep things simple and not hard on budget.I wouldn't suggest diagnosing the flight panel of the space shuttle with a DIY oscilloscope or even a usb Hantek. But they're cheap and close enough for learning the basics. Theirs all kinds of DIY kits for audio amps ,power supplies,toys,games.Even old school vacuum tube amps,radios and Nixie clocks.What ever floats your boat .Their all fun to tinker with and learn from.Thing is to just dive in and give it a try. :)
Offline rpmilius
« Reply #7 on: March 19, 2018, 05:46:46 am »
I’m a beginner and have also been on the lookout for cheap simple fun kits to practice soldering. I’ve found that searching for “electronic diy suite kit” on eBay brings up a lot of different and interesting kits for just a few bucks each.
Offline joseph nicholas
  • Country: mx
« Reply #8 on: March 19, 2018, 12:14:05 pm »
I have built the MF-47 multimeter kit on bangood and it takes a great deal of patience to put together successfully,  but the thing works and is a great supplement to a standard digital MM.  It is quite tough and can take a lot of abuse.  It also has a 2.5kv range which you wont find on the digital types.
Offline leisergeist
« Reply #9 on: March 19, 2018, 02:15:04 pm »
Those $10 eBay component tester kits look mildly useful, I'm not sure I'd personally have much use for one though.
Even if it's not terribly cheap, that's pretty neat
Offline medical-nerd
  • What's that coming over the hill?
« Reply #10 on: March 19, 2018, 03:36:21 pm »
Hiya
The airband receivers are reasonable for about $15-$20, are easy to construct and the circuit is interesting to go through.
Cheers
'better to burn out than fade away'
Offline tooki
« Reply #11 on: March 19, 2018, 07:20:09 pm »
What sucks about all the Chinese kits (and many western ones) is that, for all intents and purposes, they’re just soldering practice. And while that does have value, you learn absolutely nothing about the circuit’s theory of operation, etc. (Especially if it works on the first try; troubleshooting sorta forces you to learn a bit.) And in all the things with microcontrollers, it’s spectacularly rare to get the source code, similarly depriving you of any insight to how the thing works.
Offline paulca
« Reply #12 on: March 19, 2018, 08:07:22 pm »
This was fun to build:
http://www.ebay.co.uk/itm/282303654044
As was this:
Portable Headphone Amplifier Board Kit AMP Module Kit For Classic 47 HIFI DIY
Both very useful and I have them running as permanent items on my desk.
Offline tooki
« Reply #13 on: March 19, 2018, 08:10:37 pm »
For the western income standard, the DSO is a toy and a soldering practice kit. For the Chinese income standard, the DSO kit is a beginner's tool to learn.
And just to say, if you sell a product in China with source code, it will get cloned in no time. Unlike firmware dumping, where the credit information is preserved, if the cloner gets the source code, they will purge your company's information and replace with theirs as if they developed it.
I wasn’t stating any opinions on the final product, dude. I’m talking strictly about the educational value of getting it as a kit. No theory of operation and no source code mean that you’re buying a finished product and a soldering practice kit in one. That’s it. You learn nothing about how it works, why it’s designed the way it is, etc.
Of course the Chinese would clone the source code. This fact has zero impact on my statement that having no access to the source code is a huge limitation from a learning standpoint.
Offline tooki
« Reply #14 on: March 19, 2018, 08:13:39 pm »
As was this:
The clock kits are fun to build. But zero educational value (see above), and the accuracy of the clocks is all over the place. (I finally found some clock kits that use the DS3231 instead of the DS1302/1307, and are far, far more accurate.)
Offline oldway
« Reply #15 on: March 19, 2018, 08:51:29 pm »
Have a look on Velleman kits......
https://www.velleman.eu/products/list/?id=366970
Offline 128ITSH
  • Country: il
« Reply #16 on: March 19, 2018, 09:24:07 pm »
I usually don't like to order a DIY kit unless it is for soldering practice or an actually useful tool.
The way I learn electronics the best is by working on projects, since thinking of an idea, designing a circuit, choosing components, writing a program is far more "Do-it-Yourself" than just soldering. I'm now designing my first PCB to be printed for some project, and I learn so much out of it. (till now used Proto-Boards for my projects)
So i'd say that the best DIY kit to buy is a breadboard, some components, wires, and your imagination.
I ordered a 4 digit 7-segment board about two years ago. I intended to use it with a PICAXE but the example code from the seller didn't worked. back then I really didn't know what I was doing - I didn't know how the IC's on the board worked, how the serial interface worked, I think I wasn't even sure what current is in these days :palm:.
The result was that I had no way of troubleshooting this and I just gave up with that board.
So my advice for beginners is to only buy a DIY kit if they understand the basic principle that it is built on, and if it has a good tutorial that is also educational.
A good engineer knows how to use his tools.
A better engineer also knows how his tools work.
The perfect engineer is the one who made his tools.
Offline chriswebb
« Reply #17 on: March 19, 2018, 10:14:55 pm »
I was fortunate enough to acquire a bunch of ramsay kits. Not sure their availability these days.
Also if you have the money to spend: https://shop.heathkit.com/shop
There are a few kits there but they are pricey.
Always learning. The greatest part of life is that there will always be more to learn.
Offline tooki
« Reply #18 on: March 20, 2018, 12:16:21 am »
To spend 10x as much as the Chinese version, with almost equally bad documentation?
Offline sycho123321
« Reply #19 on: March 20, 2018, 03:19:31 am »
If you are interested in the rf side of things there are a myriad of QRP (Low power) radio kits on sites like ebay to build/experiment around with. Be aware though that for some kits you may need a licence. There are also easily modifiable designs like the bitx radio you could play with.
-KD9A
Offline Hextejas
« Reply #20 on: March 20, 2018, 05:50:00 am »
I have this kit and it works well.
I used it a lot today to try and find a matched pair of capacitors.
I think that Dave even reviewed it and liked it.
Offline oldway
« Reply #21 on: March 20, 2018, 08:22:31 am »
If you are considering electronics only financially, it is better to stop right away.
We find everything we want already mounted for peanuts, no need to mount anything.
It's the same thing with electronic repair, if you count the price of labor, it's cheaper to buy a new device.
You have to think different .... in learning, it's not the cost that counts, but the experience and the knowledge you acquire.
One of the benefits of Velleman kits is the diversity of available projects.
An assembly with through hole components is also easier for mounting and measurements than SMDs
Offline tooki
« Reply #22 on: March 20, 2018, 04:18:55 pm »
It's a money pit, which is precisely why it makes sense to not waste it on overpriced items when you can get the same thing for less.  ;D
No kidding?
You don't say…
You have to think different …. in learning, it's not the cost that counts, but the experience and the knowledge you acquire.
Please don't tell me how to think, since you have no idea how I think.
Obviously it's about the learning, which is precisely why I complained in posts above that so many kits are devoid of educational value. They're soldering practice, little more, for the most part.
You consider that a diversity of projects?!? I just see a bunch of modules, some useful (but overpriced) and others fundamentally useless. Very few involved projects producing a finished device I'd actually want to use.
I think that way of thinking is changing rapidly. I've come to see SMD as often easier to deal with. I'd much rather mount 100 surface mount resistors or LEDs than 100 THT ones with 200 legs that have to be trimmed. SMD ICs take less time to solder than a THT one of the same pin count.
Depending on the package type, there is some truth to saying that they can be harder to probe — much harder in some cases. Sharp probes (Probe Master comes to mind) make a huge difference.
Offline The_Boots
« Reply #23 on: March 20, 2018, 06:37:45 pm »
So I am also just getting started out and I also decided to get some of the kits to work with. To all who think that these are just "soldering practice" and not educational, I would say that's a bit shortsighted. It depends on how you approach them. I set out to try to find kits to make some useful devices for getting started-- in the end I decided to get a power supply kit and the component tester kit. I'm still waiting on the power supply kit, but I built the component tester last night and you're right; it was certainly soldering practice.
But that's not all it was. As I said, I'm just getting started, and the whole experience can be a bit overwhelming when you're really getting started. The kits gave me a good starting point, with a fun path forwards that ended with a working device at the end. From the very process of choosing which kit to get, I learned an awful lot. Just as an example, when looking at critiques of the Bangood power supply, I learned about peak vs. RMS Voltage for AC, how to read datasheets of components, 78xx power regulators, linear vs. switching power supplies, and lots more in between. I think that qualifies as more than soldering practice.
So far, the kits have been a kind of guided tour along the path of basic electrical components. When I pick up a new part I don't recognize, I look it up before I solder it in. Even better, the most frustrating part was that it was hard to follow the PCB traces to really follow the full circuit, so I think I want to try another design, but this time do it on veroboard so I can really dig in to what each component does.
I'm sure for people with more experience, there wouldn't be much left to gain from these kits other than a relaxing, toy-building project. But remember, for those of us with a lot left to learn, there's plenty to be gained here.
Oh! And +1 on the component tester, but if you've never soldered SMD components (which I hadn't) to try to practice a bit first. Soldering the 3 SMD parts was the first steps in my kit, and unfortunately, also the trickiest. The instructions DO say you can skip the SMD IC if you want, but where's the fun in that?
Offline paulca
« Reply #24 on: March 20, 2018, 08:03:17 pm »
There is nothing wrong with kits as solder practice either!
Buying a purely solder practice board, there is very seldom a way to verify it.  Sure they sometimes link all the resistors in some funky parallel/series config and you can test them with your meter, but the values are often the left overs like things such as 13.1mOhm so it would be hard to determine if one of the parallel resistors is badly soldered.
If you put together a clock, then if it doesn't work or goes "POOF" in a blue/white cloud then you know you messed up.
This is of course IF it does anything first time.  If it doesn't and nothing looks out of place it can be a great learning experience working out why it's not working.  I did one of the little LED chasers and one of the LEDs was out.  It was quite fun tracing things to find where the fault was.  Of course it did indeed turn out to be a dead LED, but it required my scope to find it for sure.
Besides I like my clock, my signal gen, my headphone amp and my little PSU modules.  They are all useful and I can modify them if I choose.
