I have this strange problem, it's driving me nuts! In my kitchen ceiling I have 2 lights... each is a simple socket for a light bulb and then it gets covered by a frosty white globe. The lights are up around 10 foot high and I need to get a ladder and remove the globe each time I need to change the bulb.
So I have this one light that is doing a strange thing. It was working fine for months, then a few days ago it flickered a bit and went out. I climbed up the ladder, took off the globe surrounding it, and unscrewed the bulb (which is clear). The light switch was still on. As I turned it I saw some sparks and the light went back on, so I screwed it back in and it worked again for a few days.
Then this morning the light was again not turning on. I climbed up the ladder again, removed the globe, unscrewed the bulb completely this time and looked at the filament which was intact. Nothing visibly wrong with it, no sounds when I shook the bulb. I screwed it back into the socket and turned on the light switch... again I had light. Put the globe back over the bulb, ladder back into garage.
I figured all was good..... except...
... a few hours later it does the same thing! I was upstairs, my wife said it flickered a few times and went out. I try turning on the light again and it's dead again!
Now I'm not about to climb up that ladder again until I have an explanation of what is going on! It makes no sense. Is the filament broken? When it heats up after a while does it break a contact somewhere? Then why wouldn't it light up again after the filament got cold? I have to physically unscrew and rescrew the bulb in by only a tiny amount. Could it be carbonation on the contact in the socket? Why would this happen to this socket only and is moving the bulb "scratching" the carbon deposit away until it builds up again?
I can't figure this simple thing out... Someone help!
