Schematic attached, a 1kW 136kHz Class D amp, works fine save for one
annoying issue I cannot get a handle on, maybe someone can have a
look see please?
I am now on my 4th IRFP260 switching FET in the 50 / 100V DC feed!
I have the keying socket shorted all
the time, so it's not actually constantly switching as I have yet to
try QRSS or similar. After a while I'll hear a sizzle and smell
burning. Then the 50V / 100V is permanently on, even when I un-short
the keying socket.
The IRFP260 is dead, shorted between drain and
source, and sometimes gate as well. Also, every time I find the 470 Ohm resistor
between the collector of the BF393 switching transistor and the gate
of the FET has burnt up, but the BF393 lives on. I have no idea why
it's doing this, but it did it again last night, and I am down to my
last IRFP260. Is it marginally rated or could it be something else? The amp draws about 10 Amps DC. If
I need to buy more should I look for something higher rated? Thanks.
